Chuck D. Bones
Circuit Wizard
Another great pedal from the guys at Runoff Groove. This one is designed to mimic the AC-15 tones. I built it 98% by the book. For JFETs, I used 2N5457, SK193 & SK193. Q1's drain resistor ended up at 3.9K. Q2's source resistor is 18K. Q4's source resistor is 1.2K and the drain resistor is 10K. All of the drain voltages ended up with 100mV of the values on the schematic. I added a 2.2K resistor at the bottom of the GAIN pot. I ditched the 100nF cap after the TREBLE control, it was unnecessary because there is no DC to block and it is not part of a filter. I ended up changing the BRILLIANCE pot to B100K, it had a better feel. It doesn't do all that much and could be an internal trimmer instead of a front panel control (I can't believe I just said that). I also got rid of a redundant resistor in the last stage. I changed the 220nF cap to 22nF, the 4.7K to 47K, the 6.8K to 68K, jumpered the first 47K, changed the 2nd 47K to 27K, bumped the 1nF cap up to 1.5nF and the 330pF cap to 560pF. The filter is tuned the same and uses one less resistor. Not counting the LEDs up front, this thing has four separate diode clippers and Q2 can be driven to saturation & cutoff. All that makes for a lotta compression and distortion when GAIN is dimed. Setting gain below 10:00 provides very smoother distortion and easy volume clean-up. The bottom-end is rolled-off by the 2.2nF before the GAIN control. This preserves the clarity, even at high GAIN settings. Plays nice with single-coils or humbuckers. ROG did a very good job apportioning the gain and clipping at each stage. TREBLE & BASS controls are effective. Maximum output is just under 3.5Vp-p, so it can hit your amp pretty hard it you want it to. I used a TL072 opamp, but any dual FET input opamp would work. The things I changed had no effect on the tone, they just reduced the parts count a little bit. This one is definitely a winner.
I left out the input protection LEDs. Controls are (L-R) VOLUME, BRILLIANCE, BASS, TREBLE, GAIN. Vref is on the bottom red rail.
![ROG britannia.png ROG britannia.png](https://forum.pedalpcb.com/data/attachments/24/24341-6164a02a7f972743a4cc84d2e84f4a92.jpg)
![ROG Britannia breadboard 01.jpg ROG Britannia breadboard 01.jpg](https://forum.pedalpcb.com/data/attachments/24/24345-e49d45184ce46e90d6ed82cde29ec61b.jpg)
