M800 bias question
paulbarrette
I have the board all together and am biasing the j201s. I noticed that the bottom right trimmer is cranked down all the way and i am still seeing 8.6v. The others are all 4.6ish. Is this guy not meant to go to 4.6?
Thanks
Pb
I tested the m800 without the case. Pass thru works. I have the trimmers at 4.6 except #6. I noticed it sounds more like fuzz. It is late. i will check the bias again tomorrow.
Pb
That last trimmer is just a tone control, not a bias. I just dimed it on mine since you can control the treble externally as well. Up to you
does anyone have trouble with the m800 keeping its bias? I dial it in and a few days later it is dull or bad fuzzy sound. Is this a j201 issue? Is there a way to test them? I have extra if i have to replace them
Thanks
Pb
