giovanni
I made myself a little Inkscape template with all possible knob combinations that I can use as a starting point for my artwork (for laser cutting). I copied the template bits from a couple standard PedalPCB pdf templates to make sure I would get the spacing and hole size right. Here's an image of it:
Now here's my problem. I did a test cut of my Maleficent Mids faceplate and noticed a couple issues with the knob hole positions:
Hopefully you can tell what I am talking about from the pics. Now, it's very possible that I messed up the drilling enough that the spacing of the knobs is noticeably off (although I had no issue getting the pedal in the enclosure; also I used Robert's excellent drill template), but it is also very possible that in copying the knob templates from the pdf to Inkscape some dimensions got messed up (wouldn't be the first time this happens). So I would like to double check my work by learning what the spacing between knobs is supposed to be.
I looked in this forum section to see if I could figure out the exact spacing between knobs in the standard PedalPCB templates but I haven't been able to. I guess maybe I could reverse engineer it from the Tayda templates but before going to that length, I thought I'd ask @Robert for help!
- the top two knob holes are a bit too close to each other
- the bottom knob is a bit too far from the top
