Sadly, no longer have a looper, otherwise that was my first thought.I have never used an audio probe, so just brainstorming. I don't have the pedal to do it myself, but I feel like you could use a looper pedal. Or what about your phone or something connected via an adapted 1/8" to 1/4" cable?
Doesn’t this produce a higher db signal than a pickup or is it made to provide the same output ?I use an app called Function Generator on my phone
My phone has a volume controlLooper for me…
Decided to go with this one, after looking into more. I like that it does pretty much everything I need
You chose wellDecided to go with this one, after looking into more. I like that it does pretty much everything I need
Or a black eye without a buffer
and do we add a couple cheap p-ups with no shielding below a fluorescent light's ballast?Or a black eye without a buffer
I've been using a looper pedal as many folks have mentioned but this app looks killer! Actually there are a couple on the Apple App Store. I like the idea of being able to do it all at my workbench and not need a guitar.I use an app called Function Generator on my phone
Nope, I have a cheap bullshit android phone with a headphone jack it's bad at almost everything else but has a headphone jack and micro SD slotI've been using a looper pedal as many folks have mentioned but this app looks killer! Actually there are a couple on the Apple App Store. I like the idea of being able to do it all at my workbench and not need a guitar.
edit: @Harry Klippton did you make a custom cable to get the signal from phone to pedal? Being an apple use I have to deal with the bloody Lightning plug....thinking about what adapter I need to convert to 1/4" phone jack.
second edit: Duhhhh....I have a whole bunch of those Lightning to 1/8" dongles, that's all I need.
