Im a big fan of these!
I sometime use those too depending on the design, but the insert provided with them is not snug enough so the led tends to drop in.I don't use ones with their own resistor ever so I can't really speak to that. As far as tayda pre drills, you have the pedalpcb ones and the generic ones. For pedalpcb you have 2 options.
https://www.taydaelectronics.com/3mm-led-lampshade-protector-clear.html
This plus whatever 3mm LED you want or
This exact red LED is tapered and will fit in the hole about halfway up securely, which I do on my builds.
As for the generic predrills 1590bs,
these two have fit for me, with 5mm LED of your choice.
I get them from Tayda.Does it require a larger hole? Where can I find those?
If you are using the Tayda drill template, you'd want to set the diameter of the LED hole to whatever is required by the bezel you choose.What bezels will work with the predrilled Tayda enclosures? That's probably where I'll start.
I'm fond of 3mm, no bezel, my favorite being flat-top water clear
I use theseI really like those. Where can I find them and how do you attach them on the inside?
These guys have lots of nice ones in various sizes: https://lighthouseleds.com/led-component-lighting/diffused-leds.htmlI really like those. Where can I find them and how do you attach them on the inside?
