Bootleg Overdrive
Travis
Hi everyone!
How can I mod this pcb for bass?
I want to control more low end with the tone control, I use It the knob at 0/10%.
Thanks!
The main culprit to play with would be C8.
You could try a reverse taper C5k for the pot.
R9 & C7 are forming a low-pass filter, so you could play with C7 as well.
I'd also increase C10 to 220n, C3 to 47n and maybe even breadboard the circuit and swap all the 1µF caps in the signal path for 2µ2. Might get too muddy at that point though.
It's a hit & miss method, whereas somebody who knows what they're doing such as @Chuck D. Bones would just do the math and change only what's necessary.
