CanadianDave
I haven’t posted anything on this forum in ages, cause I’ve been busy with a lot of projects.
Covid has me laid up for a week, so here we go…
This is my EQD Arrows boost. It’s powered by a 9v battery that charges via USB. One toggle is the bypass, and the smaller cuts the 9V power, so it doesn’t drain power when I’m not using it. As a bonus, if you cut the power while it’s ON, the draining power in the capacitors gives you about 30 seconds before the sound fizzles out and fades to silence. Kind of a cool way to “fade to black.”
I cut a panel to cover the battery, but you’ll see the usb charging port (I still plan on making a cover for the port)
Enclosure: hand built Fender Meteora clone.
- Fralin P90, and a Mojotone gold foil pickup.
- Swamp Ash Body
- Quarter sawn flamed maple neck
- Crelecam Ebony fretboard
- Mosaic Pin inlays
- Champagne Gold Acrylic pickguard with rounded and polished edges
- acid etched brass plates
- acid etched nickel hardware
- a relic finish that got a little out of hand
- coil cut, La cabronita wiring with oil in paper capacitors, and solid brass knobs
- Customized zero fret
Everything made by hand, with the exception of slotting and radiusing the fretboard
- Swamp Ash Body
- Mosaic Pin inlays
