andrewsrea
I am battling a client's science project amp repair (1970's Sunn Beta Lead solid state), where I get proper signal right up to the inverter circuit, which is clipping on both half's of the push-pull and phase cancelling the output. Thus the amp output to the speaker is almost nonexistent and has a malformed signal compared to the original 1K sine wave.
The PNP side of the inverter tested well for continuity (diode test) and had an hFE of 27 on my DMM (a little lower than I expected, but my DMM is low voltage vs. the requisite -40VDC).
NPN side is a 2N3440 that passed the diode continuity test, but registered '0' for hFE, which is typically indicative of a short. So I have conflicting results.
I was wondering if any of our solid-state gurus have had similar experiences like this and any recommendations for steps forward. I'd hate to throw money at this amp, by ordering a replacement, especially that replacements are not NOS, but Asian versions (which are typically hit or miss).
Please ring in if you have any ideas.
