"Sub Fuzz" - Waddlebox + Squidward
zipfool
Made this for a friend who plays bass. He uses something like Boss FX-25 with both knobs turned almost all the way down and it gives the bass a boost in the sub frequencies. He also wanted a unique fuzz tone added to it.
So, I combined Waddle Box with Squidward and found a way for them to share an RGB LED. I ordered the powder coated/UV printed enclosure from Tayda.
Lessons learned:
- Common anode RGB is the way to go for shared LED
- Always sand off the powder coating on the inside of the pedal, particularly where the jacks make contact. Same with the enclosure cover, where it makes contact.
- If you can ensure solid connections between the jacks and enclosure, there's really no need for more than 1 ground wire per PCB.
Gorgeous layout and execution!
Do you have the source of the illustration?
Sure, the original source of this illustration can be found on DepositPhotos:
I had to do quite a bit of work to get everything lined up and colored the way I wanted it.
