Most electro caps are 20% tolerance. The tolerance is not what made it big, the manufacturer is haha. You should be able to find 220uf caps at 35v that fit, make sure to look at the dimensions when ordering. I believe standard on most boards is a 2mm lead spacing with 5mm diameter.
