3D Printed Resistor Tester Stand
Hey pedal builders, I recently found a fantastic 3D-printed resistor and diode testing stand that I wanted to share. It features metal inserts, which are perfect for quickly and accurately testing components with your multimeter. I've been using it for a while now and it's definitely a time-saver!
If you're interested, you can download the STL file here:
-> Resistor Tester Stand
Here's a video that demonstrates how it works:
-> Electrical Resistor Stand w/Metal Inserts for Ohm Meter
I like it.
When I'm testing resistors I inevitably wind up bending the leads in the process ...
(which doesn't really matter 'cause they'll get bent when I go to populate a PCB with them).
I'd probably wind up bending the leads using this Resister Tester Stand, too.
Unnecessary, but ... I like dodads and gidget-gadgets — my bench is cluttered with such things.
For example, I got one of these that I never use:
The Resistor Tester Stand could sit next to the bender.... SQUIRREL!
Gotta get me one of these!
I like this Transistor-leg bender. Another thing I'd buy and then set next to the resistor-leg-bender.
Anyway, I like the idea of the Resistor Tester Stand, alas I don't do any 3D printing.
Yeah,, I have a resister bender that I 3d printed, I use it all the time to bend resistor and diodes. I'm not into guess bending resistors with needle nose pliers. I was going to get one these U and F Type Resistor Axial Lead Bend Cut & Form Machine from Aliexpress to crank out heaps precise bent resistors, so I don't have to bend resistors. lol..
Makers World (Bambu Labs - 3d Printing Models and Community) has alot of good electronic tools and gadgets.
Resistor Bender
Soldering
  • Resistance Molding Machine _ Resistor Lead Forming Tool _ Forming Molding Machine - U_f - Alie...png
That is so cool! Do you have an stl file for it? Or whichever file printers take lol
that is so unnecessary, wow
Totally disagree. It's not super useful to measure one resistor, but if you have any number at all, being able to throw each one into the jig and not have to mess around with multimeter leads seems amazing. I won't get one printed, but the second I need to sort a bunch of components, I'm coming right back here to this post.
It’s not about using it, it’s about being able to use it if you wanted to. 🤣 I’d love to have one I’m not using, also. I also have a drawer full of cool things…around here somewhere.
That Gattlin' Gun-like Resistance Molding Machine looks like fun.
Any time you've got to batch process something, a little widget here, a grapple-grommet meshing with a filber-flange there...ADDS UP to a lot of time saved.
Bending solder, well... I dance a little jig every time I'm about to solder — I haven't jigged for ages, reeling from it.
@Feral Feline - so I made a first draft CAD design of a "wire-bending" TO-92 transistor tool, will print it later this week for testing. The basic idea (a.k.a. "hope") is just to press the transistor down into the slots (also pressing down on the leads). We'll see...
Screenshot 2025-03-03 at 6.27.29 PM.png Screenshot 2025-03-03 at 6.28.24 PM.png
Front and back views, the whole thing is just an inch high (25mm).
@GAStan kindly reached out and made an excellent suggestion, to make a 2-piece design with a base unit which holds the TO-92 transistor plus a hand tool (a.k.a. 'lead former') that bends the outer leads into the correct shape. So here's an attempted design for that. What I haven't done yet is test print it, lol... As there's some fine details here, there's ample reason for this to not work out so well. I'm working on printing both the previous 1-piece design shown in #13 above, as well as this new design. We'll see, give me a few days' time - and please cross your fingers.
Here's the base unit that would hold the TO-92 transistor (flat side face down).
Here's the hand tool, in roughly the right orientation that would slide into the base unit to bend leads 1 & 3 so that they now align with 0.1 in (2.54mm) lead spacing.
And here's the underside of the hand tool.
A short update - I still need a little refinement of the design, as while it does bend the leads to the right spacing, the end of the transistor's lead are not fully straight. Here's the prototype in action:
Pic 1: transistor loaded
Pic 2: hand tool fully pushed in
Pic 3: end result
I had a transistor lead former years ago that was basically just a small solid block with three holes spaced 0.1" apart.
All you had to do is push the leads into the holes, perfectly formed every time... with that said, I usually just push them into the PCB unformed and let physics take the wheel. 😂
Pic 3: end result
View attachment 92456View attachment 92457View attachment 92458
This is really cool... you could argue it's unnecessary, I'm sure, but people should do whatever makes the process more enjoyable for them. I have a 3D printer and would love to give this a whirl.
Yeah I get that people like testing things to be sure, but if I didn't trust the manufacturer to print the write value on the resistor, I just wouldn't buy from that manufacturer. Checking one or two here and there is fine, but if I had to test every single resistor I used I would be up all night without even firing up the soldering iron.
Pic 3: end result
I think that’s awesome. Even with the legs not perfectly straight, it takes a millisecond with your thumb to push them apart and you’re good to go. That initial bend at the top of the legs is the important part. So much better than my system of using a pair of needle nose pliers to create that bend.
Man, I wish I had a 3-D printer. I actually like the idea of the resistor bender as well because you have so many different lengths of bends when you do stripboard and if it’s not exactly right, it can look sloppy - I looked on Amazon, and, being Amazon, the cheapest ones they offer are $10 or more, and sometimes my need to preserve my wallet outweighs my need to preserve my sanity on bending resistors perfectly.
