Has anyone come up with a quick and dirty way to add an indicator LED to the 3PDT Order Switch? I was thinking it would be cool to have a bicolor LED indicating which of the sides was "first"
That depends on if you're using a common anode or common cathode device.
EDIT: Betty's drawing below is for the bi-color two-pin LED that I hadn't considered. There are some options here and they will determine how you set it up. Below is probably the simplest.
