I mean, obviously you want to shift some controls more into the lows and in particular in the low mids. You absolutely want a control on 100hz. Back in my recording engineer days, we called 100hz "mud," you always inevitably wanted to dip a little 100hz for clarity.
5Khz is often associated with "sparkle," but it can fatigue the ear
(A common problem is engineers turning up the 5K on hat and cymbals, then an hour later thinking they sound flat, turning it up, etc etc until your mix is a brittle mess.) Tiny bumps to 3K can accomplish a similar brightness to bring out the metal in yer bass strings, if that's your thing.
Even with the warning in the mid-range
(800hz to 2.5Khz) with your chart above, you probably want to to pop or cut a little honk in yer bass sound.
All of which it to say it kinda depends on what yer tone goals are. Are you looking for metal bass? Jah Wobble? Versatility?
The generic 7-band bass graphic is usually: 50 - 120 - 400 - 500 - 800 - 4.5k - 10k (but that 10K is fucking useless)
For
versatility, I'd start at mebbe: 40 - 90 - 250 - 550 - 1500 - 4.1k
(YMMV)
But if you really wanna get
your sound, either breadboard or socket those two capacitors on each band, use a filter calculator and tweek each and play through it. (I think most of your tweeking will be in the 250hz to 1500hz range.)
For reference:
- Boomy (40 Hz – 90 Hz)
- Fat (75 Hz – 150 Hz)
- Thin (40 Hz – 180 Hz)
- Power (40 Hz – 150 Hz)
- Impact (40 Hz – 150 Hz)
- Clarity (190 Hz – 800 Hz)
- Presence (800 Hz – 6.5 kHz)
- Attack (120 Hz – 4.1 kHz)
Hope that helps.
