9v Simulcast
palbjorno
I am about to build a Simulcast, but I would like to run it at 9 volts. Do I remove the parts before or after d100. Also, is there anything else to worry about?
Thanks
As far as stated in previous posts on this build, you could also build it like normal and just socket the LT1054. Leaving it in will give you the higher voltage. Taking it out will give you 7.5v I think. That's how I use mine, with the chip out. I love it. Clean to nasty.
interesting ..............
Omit IC1, C12, C13, C14, C15, and D5.
Install jumper wires in the place of D1, D2, D3, D4.
If I only have a 18v tap available on my board would it be better to omit parts like that or just omit IC1 which would make it run @15v if what I've read just above is correct?
By "better" I mean closest to stock circuit @9v input. BTW is it possible to run it @18v with the cap values indicated in the build doc?
