Hallo, i need help with the Abyss. I build allready few Pedals all worked but this one ist friggin me out. Its the Secound try to build this Pedal and it still not works.
The yellow led works with the potis and is pulsating. The Status led is on bypass mode a little bit on and when i change the mode its Full turnd on. But the sound doesn't work. On bypass theres no sound and when i switch it on theres only a Ground Buzzing. I allready soldert all connections new.
Someone a idea what could be the problem?
Greetings
Robin
Greetings
Robin
