Abyss
cooder
Great! How do you like it and he soundz?
What LDRs did you use and did you match or test them? LED is diffused yellow from Tayda?
I find on mine the Throb doesn't do that much, is that the same for you?
Cheers.
chongmagic
Cheers.
It sounds decent, not really my favorite vibe, not sure if you could call it a vibe. I used the Tayda photoresistors.
Photo Conductive Cell Resistor LDR 650nm RADIAL KE-10720 (taydaelectronics.com)
I didn't match them, I have used them in every build of this pedal thus far.
Yep the diffused yellow LED from Tayda as well.
Throb maybe changes the sound a minute amount but not much.
The Photon vibe and Duo Phase are probably my faves, I have a Photon Vibe on my pedal board as a matter of fact!
susie_1987
for the photon vibe is it ok if I use 1/4 w resistors or that does that affect the behavior of the circuit?
Robusto
Mine doesn’t really seem to do much at all other than act as a preamp. I wonder if I just need to play around with the LDR placement? Do they seem too low?
