jeffwhitfield
So I've built a few dual overdrives: a Paragon and a Pro-10 green/blue combo. Both have their perks and sound really good. But after thinking about it, I really came to the conclusion that having separate pedals made more sense to me. I like the Protein...but really wish the Green channel had a bit more flexility. I have an Andromeda Deluxe (ODR-C) which provides the same tones as the Green channel but with more flexibility. I like the way a single channel sounds on the Paragon over the Pro-10 Blue. They're both good, mind you...it's just that the Paragon sounds a bit better. So, basically, I wanted the best of both worlds.
As such, the best solution would be to pair up the Andromeda Deluxe with a Prince of Tone clone. Choice was between a PedalPCB Pauper and an AionFX Achilles. Ended up choosing the Achilles...mainly for the extra MIDS dip switch. Just adds a bit more flexibility in the tone. Used the same op-amp and diodes I used the Paragon so we're all good.
Tone is spot-on with the Paragon and pairs up quite nicely with the Andromeda Deluxe. Just like the Pro-10, I found that running the Andromeda into the Achilles resulted in the best sound. It's amazing how much of a difference the added controls on the Andromeda makes compared to the Pro-10 Green, especially the Mids and Low Cut controls. Mashed up with the Achilles, I feel like I can really dial in tones that I wouldn't otherwise get with the Paragon or the Pro-10.
