Barnshart
Essentially I want to put a Muff, RAT and Tentacle in this one enclosure and then wire in 3 way clipping sections to the diodes in each board.
I've got everything on the PCB soldered in other than the diodes. Am I correct in thinking I can simply run a wire from. either end of D1 on the muff to the middle lugs of my DPDT on/off/on and then add my diodes to each side of the switch? Do I need to run wire to D2 of the muff as well? Same goes for the other half of the diode section to a second switch etc...
Essentially, want to know if I need to jumper D1 & D2 together and then run off to the switch, or if I can simply leave D2 totally empty? I did this mod on my Proco Rat and didn't need any wire running to the second clipping diode, so I just want to make sure.
