TravisM
This was my third build and it went really well. I only had to fix the on/off indicator LED as I put it in the wrong way the first time. I guess now is when the overconfidence starts to set in and I'll doubtlessly be humbled in the near future 😆. The 2.2 uF and 1 uF WIMA caps I bought took more board space than I anticipated, but I was able to get them in. I had to solder the ODC pot into place first in order to not block the solder pads for it. The build was otherwise straight forward, but I missed not having the values of the components printed on the PCB itself.
I used the Tayda custom drill service for this enclosure as the last time I tried to drill the holes myself, they were off a bit and I didn't want to mangle another enclosure. If anyone wants the template, it is here:
If you use it, adjust the LED and power plug holes to fit what you will be using.
Now, I need to figure out the graphics part which has never been my strong suit.
