Another Simulcast build question - D5: the 15v diode
Crookedtooth
Hello! I'm having a hard time understanding which 15v diode will work best here. Any ideas? Very new to electronics and pedal-building, so any help you have would be great. Thanks so much!
Crookedtooth
Thank you! I will look for one. Also, while I have you, any thoughts on that 450r resistor? I don’t see any resistors available of that value... thanks so much!
the_grumpy_gnome
Usually eBay. But if you still can't find the exact value, resistors (and caps) have a tolerance: You can buy a set of 20 or so values of a very close value test each one and use the one that's the closest to the value you need.
That said, I looked at the schem and you can almost definitely use a 430 or 470 (very common) in that spot with almost no difference.
