p_wats
Not really a build report or anything, but I'm high on adrenaline from having just done some risky FV-1 brain surgery.
I've been feeling like a bit of an idiot lately, as I keep somehow damaging FV-1 chips by pushing builds a bit too far. The good news is I've gotten pretty good at removing/soldering them!
One of the damaged ones seems fine aside from the fact that it's stuck on internal programs (confirmed in multiple circuits). I couldn't help but notice the Leprechaun only needs the internal programs to work, so a devious idea was born.
Long story short, I carefully desoldered the FV-1 from the Leprechaun and replaced it with the one that's locked to internal programs and it worked!
That means I can use the working FV-1 to replace the one I'd already stolen from my Deflector PCB to fix a half-built Arachnid, completing the 3-way brain transplant.
You can see from the above photo (before I had finished all the transplants) that I have somehow damaged 2 other FV-1s(!) in my travels: one now only emits noise and another has a loud high pitch whine (both were working fine until I shorted something out).
The moral of the story is that if I can do it, you can do it, but also that you should never need to do this if you build more carefully than I do! Basically, don't listen to me, but if you end up in this situation, it's not that hard with the right tools (some low-temp solder is key).
