Hey guys this is a long thread at Strat-talk, these are a couple posts from there I copied just to see if anyone has ideas about my guitar. If you are interested and like reading (a lot), here's the link, there's sound clips:
I have an 2008 Fender American Special HSS, I don't really have string break issues, but I got this G string warble I'm trying to diagnose. I know it's...
www.strat-talk.com
Graphtech saddles did not help. Problem persists, warbly sound on every string somewhat except high E. Even on 22nd fret, so nothing but string and saddle after that.
Even if I pluck the string very gently, I can still hear it. This is with overdrive on so I can hear it better. Notes ring out fine, duration-wise, just not a true constant tone, warble continues as the note decays.
Tightened baseplate screws, they were fine as is. Went up and down guitar listening for buzzing. Everything is tight nothing abnormal. Action is high enough not to have fretting out of notes, they all clear the next fret as you go up the neck. I dunno my energy is spent on this. I guess I'll try a new bridge but not hopeful.
So sent Graphtech saddles back and took it to a tech/luthier for a few days. He said it's my hot bridge pickup magnetic pull, that I use too much gain, and that I'm being too picky. He suggested taking my humbucker out and try that, since I tried removing the single coils.
So here's with no humbucker and heatshrink wrapped around a few strings at the ball end and up thru the baseplate just as an experiment. Warble persists.
Listen ya'll I'm no tech, but remove bridge pickup and I'm too picky? Single coils almost always have more pull. The G string sounds horrible! Other strings sound horrible 12th fret and up.
Ordered a Gotoh 510, didn't work.
At first I put just the bridge on without its hardware, and I thought I heard improvement. So proceeded to swap the bridge assembly hardware. I wanted to change everything, so the trem claw/screws, springs, bushing and studs all got put in.
I could say there's a very tiny bit of improvement, but its probably the new strings. Every note on the G string sounds just as before. Also the a, d, b strings in that 12th fret and up still have that shaky warble.
I will say the Gotoh bridge is pretty nice though. Fit perfect, just barely with zero filing. Tuning stability is better. It sounds good tone-wise. The slightly larger string spacing of 2 1/8" is barely noticeable and I like it anyway.
So I'm left to think it's literally the body or the neck. I tapped up and down on the neck with my ear against it with no strings, and it sounds solid. I've done that all over the guitar trying to find something. But I can't help to think there's some sorta truss rod/neck/body resonance issue.
