1N4118 is a 27V zener diode so it's definitely not a substitute across the board, but if these are being used as clipping diodes (which I assume they are?) then the 1N4118 will work if you don't have anything else.
Inversely however, if the circuit called for the 1N4118 you would not want to use the 1N4148.
