Further to my post above…
The jacks I put in my amp were switching jacks, for the sake of comparison in the following sad tale, kind of like having
Tip
Ring
Sleeve — ring being the switch, and they were
dirt cheap.
These super-cheapo jacks had a different order:
Tip
Sleeve
Ring.
The super-cheapies were so soft that plugging in a jack would be enough to warp the jack and disrupt the switch contact — plug and unplug once or twice and the switch no longer made contact. I fixed them a few times before realising they were made of butter and would never work correctly.
So I installed less cheap jacks I had on hand, with the different order (actually the correct order common to most jacks), but I swapped the wires over to the new jacks in the same order as the old (incorrect order) jacks. So it took a while to debug, so…
USE A DMM!
I’ll be replacing the less-cheap jacks for some quality Switchcraft, Neutrik, or similar established brand…
Hard to tell at a glance the cheap crappy-jacks from the expensive high-end ones, unless you’re looking at the price tag in some cases.
So, whether you build pedals, amps, or anything on a budget, there is a quality threshold that you have to decide upon, and how much you are willing to spend; but take note — something cheap may cost you more in the long-run in terms of not just money, but also time, aggravation and mental well-being!
There’s a reason “buy once, cry once” became a thing.
