djmiyta
So I finished this up checked it before boxing , boxed it up , played it , put it on the shelf. 1 week later put it on the board and lights up no sound but by-pass. I socket all clipping diodes tranny's and IC's and anything I want to change out. i use the milled sockets that are much better than the other type but! they cant be used over and over cause what I found is the clipping LED's are all loose in the sockets I replaced them, no sound, audio probe it and I lose the signal right after it hits the board signal in hits R1 and C1 and I get no signal. Solder joint? but it worked just fine before and no the box never got dropped or jarred. So now I know my signal is dead there what do I do from here? Re flow? Replace? Get rid of the sockets? I also socket the LED's cause of the mix up some boards have had concerning the orientation of LED's on some boards . So anybody have an idea? Guess pictures are gonna be needed .coming up
