Audio Surplus Effects OK Doomers
These are actually somewhat decently priced, at £99.99. But Audio Surplus sells them only routinely in small batches, for hype creation, I suspect. So, give me that clone instead of the real thing!
When you look at their earliest posts on Instagram, you see they're into cloning too. Maybe they can be bullied into selling PCBs at some point, considering their origin.
The Massenpanik would be cool too:
"Massenpanik is a highly adjustable distortion pedal that takes the cascading op-amp gain section from the venerable Providence Stampede (as used by Converge, Amenra et al) and pairs it with a powerful 5 band graphic EQ for ultimate tone sculpting capabilities. For V2.0 the boost toggle switch has been changed to a potentiometer for greater control over the amount of pre-gain boost. A presence control has also been added to cut or boost the higher frequencies above the treble control to better accommodate brighter or darker amps."
