Auditorium Test Platform
Fishbonetabby
I just as threw this together yesterday. It's pretty clear how to use it with pedalpcb builds but would someone be able to explain how I could use to to test veroboard projects like this dba example? Thanks a lot!
Depends.
Is your vero build ready to go? You’ll need to solder some wires for the power, ground, input, and output. Connect the power to the rails and the in/out to the corresponding sockets.
Or are you asking how to breadboard a vero layout? That requires a bit more skill to trace the layout and convert to a schematic or build it as you trace it
Depends.
The vero is ready to go. I have all the wires spliced and ready to solder when I get a break today.. What (if anything) from this vero layout would go into the sw socket on the test board?
This may help you during the build process. Make sure your cuts and tracks are clean before testing it
Man this thing rips! I substituted the mpsa05g's for a bc108 and a bc109 because its what I had laying around. I accidentally ordered this 1590b enclosure that doesn't leave me with a lot of room but I think with some squishing it will work. It won't be pretty in there but this is a really great sounding pedal. On one end it's a thick meaty fuzz and on the other it's got that ripped speaker/dead battery sound.
I can't stop building these things. This one is a Death by Audio Fuzz War. I built this handy little project box for the test platform too that is great for testing these veroboard builds.
