Awful Waffle - Lights but No sound
jetfeeds
Hey Legends!
I've run into some issues when assembling my first Pedal PCB build. From the audio jacks I have the signal from sleeve to sleeve but not tip to tip - any idea on how to find out exactly where the issue lies?
I think the bottom row of your switch is wired incorrectly. It looks like it connects to the central pin rather than bottom right. Check it against the build doc.
How does the bypass work in this circuit?
Bottom lugs connected is "On", i.e. LED connected and P1 to ground.
What is the bypass state then? Ground is lifted and P1 connected to P2. I've never seen this configuration before.
