You need a switching 2.1 mm jack to take the battery + out of circuit when you plug in a power supply, otherwise you send voltage to the battery, which will then let out the magic smoke!
If the battery is not inserted when the power supply is, and vice-versa, it should be ok..
Thanks Robert! I thought that was correct just wanted confirmation. I re-ran the wires to the underside of the board and connected to the correct side. I figured it better to ask than just hope for the best! LOL
