The Benson or the BYOC?I might just have to buy one cause it’s pretty damn cool.
Edit: I bought one
The Benson. Should have it Monday.The Benson or the BYOC?
By dive into it do you mean play the hell out of it or open it up and start tracing?
Maybe bothBy dive into it do you mean play the hell out of it or open it up and start tracing?
It’s really nice to play with. Sounds clean and there are several different types of sounds to get out of it. I haven’t had time to learn how to get to the waveform and tap division menus yet.Well… what do you think of it?
This is what I want to know tooHow does it compare to the other PT2399 competition? In terms of sound, not features
Well, my Echo Royal "works", but sounds like trash. I need to troubleshoot. Every demo I have found so far makes me question my building ability. Mine sounds nowhere close to as clean as them.This is what I want to know too
PT2399 chips are not terribly consistent in my experience. Before you go too far down the rabbit hole, maybe pop a different one in and see if that helps?Well, my Echo Royal "works", but sounds like trash. I need to troubleshoot. Every demo I have found so far makes me question my building ability. Mine sounds nowhere close to as clean as them.
This ^^^. Try several chips and ideally from different sources. I usually buy at least 2X what I need so now I have a good stash to pick the least noisy ones from.PT2399 chips are not terribly consistent in my experience. Before you go too far down the rabbit hole, maybe pop a different one in and see if that helps?
I have a whole bunch of em too, but I still wonder if they're just all bad.This ^^^. Try several chips and ideally from different sources. I usually buy at least 2X what I need so now I have a good stash to pick the least noisy ones from.
This is my one exception to the general troubleshooting rule of don’t start swapping components until you know what’s bad lolThis ^^^. Try several chips and ideally from different sources. I usually buy at least 2X what I need so now I have a good stash to pick the least noisy ones from.
