Bi-colour LED for Thermionic Deluxe Channel Select
Hexjibber
Hey all,
Hoping someone may be able to help, as the title suggests I'd like to use a bi-colour LED to indicate the channel on an upcoming Thermionic Deluxe build I'm planning, can anyone shed any light on how I would go about this? I've done a bit of Googling but can't seem to find a simple wiring diagram that applies to this use case as unsure how it would work given the pads on the board. I also found a build report on here that had done what I was looking for but alas they weren't able to help as have since sold the pedal.
I found this on DIYStompBoxes which more or less makes sense but can't see/understand how to adapt this to the TD board connections.
Would greatly appreciate any help anyone can give!
Cheers,
Graham
Jiuk
1. Mid-leg of bicolor LED connect to "A" on PCB.
2. One of side leg connect to "K" on PCB - it's channel A.
3. The other side leg connect to No.8 pin on footswitch (middle of bottom row)- it's channel B.
That's how I build.
Hexjibber
That's how I build.
That's perfect, thanks so much!
