Blackout Mantra
Tremster
Never seen a DIY version of this, although it was quite popular some years ago.
"Equally capable of invoking the sacred sounds of a classically refined overdrive AND summoning wickedly raunchy drive, with more crunch on tap than the overdrive moniker usually entails. With such a wide palette of tones and character the MANTRA will feel just as at home at the feet of the stalwart blues crowd as it will the quintessential rock & roll protagonists.
The MANTRA utilizes amp-like circuit architecture, with multiple cascaded MOSFET and JFET gain stages to insure the most natural, touch-sensitive overdrive conditions possible and a seemingly endless range of clean-up with your guitar"s volume knob. We burned a lot of midnight oil to make sure that the MANTRA could get down with vintage-type, low output single coils and hot humbucker pickups alike. From gently fingerpicked melodic phrases to bludgeoning riffs that you"ll want to play over and over and over..."
Schematic etc.: http://revolutiondeux.blogspot.com/2012/07/blackout-effectors-mantra-overdrive.html
There was a version available with a Low Gain Switch which bypassed a gain stage. I can't find a schematic for that though ....
Wow, that was fast.
Thank you!
Edit: 150k trimmers??? Is that an American thing? I just checked the usual shops here in Europe, none have 150k trimmers.
Could these be replaced by 100 or 200k?
FYI - Kyle is selling his remaining stock of enclosures and boards for this pedal on ebay. Included in the listing is the BOM, which shows 100k trim pots. Mantra OD.jpg
