Would love to see some boards for the Bondi Effects drive pedals (Del Mar, Sick As, Breakers) but I've not encountered any schematics. Chatter seems to suggest that the Sick As is a Klon circuit with a baxandall tone stack?
I think the current Sick As is V.3, Soft Touch Buffered Bypass with Surface Mount Design.
V.1 was True Bypass with standard components.
V.2 was Soft Touch Bypass with standard components & an intermittant Beep or Popping noise when Engaged hence V. 3 .
yeah that’s what I’ve read about the sick as. Fwiw I built a Klon circuit with a baxandall eq and wrote up how to apply it to the pedalpcb board. It’s not gonna be exactly the same as the sick as, but a similar idea. I think it works pretty well.
First off, I should note that I actually built my Klon off of a different supplier's PCB, before I knew about PedalPCB. But, I wanted to share it here to add to the mods section of this forum. I wrote all the component numbers with reference to PedalPCB's schematic for the Kliche Mini. VOICE...
