i think it's an issue of the corner of the stop band vs pass band. since 4.2k is the -3db, there's a ways to go until you reach the frequencies that aren't cut off at all. cut off is around 70% or so. so that being the case, 4200/.7 is about 6k. considering the pretty large gaps between notes in that range(200-300hz) , i'm assuming that being ultra accurate isn't that big of an issue. then again, not an engineer, so i may be way off base.
