For years now I have been very happy with my home-brew amplifiers, especially my beefed-up 5F4 tweed Super 1x12 combo. But recently I have felt the need to (a) try something else and (b) find an amp I like with my Strat! I remembered that the amp I liked best for the Strat was the Super Reverb RI I used to have. But I didn't want an amp that big. So I thought why not make a "stealth" amp... an amp which looks like a small amp, is easy to carry like a small amp but which sounds at least as good as a Super Reverb for my Strat? It should sound good with my other guitars, mainly a 335, a Les Paul and a Gretsch Duo Jet.
So I bought a recent Deluxe Reverb RI. I don't know if Fender have made any significant changes recently but this DRRI certainly sounds better than the last one I played a few years back. Stock it is a pretty decent sounding amp. It has a Jensen C12K speaker which actually sounds alright. Previously I had played DRRIs and they sounded thin and a bit nasty but this one is quite full and crisp sounding - a good start.
My plan is to go slowly and make some changes, listen, try something else, listen...
So after comparing the schematic with a Super Reverb the first things I did (after installing a Celestion G12H and testing it - good but not necessarily that much better than the stock speaker) was open it up and try a few things with the tonestack. Firstly I removed the bright cap - instant improvement for my ears. Then I swapped the 100K slope resistor for a 56K but to me it didn't sound quite right - yes there was a bit more midrange but it just sounded wrong to me. So back to 100K for the slope resistor. Then I swapped out the 6K8 midrange resistor off the bass pot to 10K - so now I'm simulating a Super reverb with mids on full. Better! Replaced the treble cap with the same value but in silver mica, the bass cap with a .1µF blue Sozo and the mids cap with a .022 blue Sozo, again as per the Super reverb and now it sounds a lot fuller but still very BF Fender. I was surprised at how much difference the .022 mids cap made over the .047. It really does add mids which seemed kinda counter-intuitive.
And lastly for now I added a .0022 cap across the 220K resistor off the reverb pedal socket. It stops a lot of the noise from the reverb. This is a tip I picked up from the AB763 Mods page: https://robrobinette.com/AB763_Modifications.htm#Reduce_Reverb_Noise
I'll play the amp like this for a while, but I have a feeling this won't be the end. With an upgrade power transformer from Mercury Magnetics and a few dropping resistor changes I can run KT77 power tubes which will really make it punchier and louder. This is a fun project.
