Coda
Be lately been breadboarding. I started with the Small Bear Fuzz Face tutorial (Si), and have been messing around with that for a bit. After that, I build a Vox Tone Bender (Si), which follows the basic skeleton of the Fuzz Face, and adds a bit. I prefer the Tone Bender, and have been swapping out stuff on the Fuzz Face.
Today, I decided to try to breadboard the Mosrite Fuzz Face, from the schematic. I did my best, and ended up with a circuit that passes sound. However, that sound is pretty clean. No fuzz at all. I started with 2n3904’s, and even tried 5088’s (I have them in my PCB build, and like them)...clean with both.
I’m not expecting a complete resolution. I should probably try again with a different layout, but I thought I’d ask anyway. What might my issue be? I’ve attached a photo, but I doubt it’ll help much. Also, I am out of 470k resistors, so I used (or tried to use) 2 220k resistors in series. Maybe that’s he issue? Also, I’m out of B500k pots, and I substituted both a B250, and a C500k, with the same results. I also have the jacks and battery removed I’m this particular photo; input at B2, output at B25 ground on the side of the pots, power on top...
