fxwiegand
I just got a DigiTech Whammy that is not working. Just plugged it in and I am only getting the dry signal through, no LED turns on, none of the switches seem to do anything. I don't really have a place to start so if anyone has a good idea where to start I'd appreciate anything you've got. I also noticed that some spots for IC's and resistors seem to be empty (see photo). I only measured the voltage of the power supply which was around 8.7 or 8.3 V if I remember correctly. I didn't measure the current (not really sure where I should). Maybe there is just not enough current since it consumes quite a lot whit its 1300mA. Although it seems to be the original power supply so I doubt that the problem is there.
