I don't have the Byrdhouse PCB (because it's a Dyna-Ross derivative that kills bass), but since no one else is chipping in I'll try.
According to the good ol' Electrosmash site (yay! it's back online!)...
MXR Dyna Comp guitar pedal analysis by ElectroSmash.
www.electrosmash.com
The 2K trimmer resistor adjusts the bias currents of the OTA differential inputs, trying to make a perfectly balanced OTA. Imbalances in the + and - input pins can make the OTA noisy as the signal change levels. In practice, this trimmer is adjusted to the middle position and in very very very rare occasions it is adjusted to any other value."
Check out the analysis at Electrosmash, which may help clarify things for you.
At any rate, mark the trimmer where it's at, mess around with the trimmer and see what effect it has on the circuit and then set it back where it was (or to whatever sounded best to you).
