Byzantium BOM assistance....
MichaelW
Hey all,
BOM calls for a 47u at C103.
C103 on the board silkscreen says 10u.
BOM has no 10u.
I'm assuming it's supposed to be 10u?
TIA!
47uF is correct, it's a filter cap for the Vref supply so either value will work fine.
I'm using 47u tants and they're "marginal". Probably going to need a bit of "English" to get them to fit. If I can safely sub 10u that's one less set of contortions to deal with hahah....
It'll work fine. I built the first one with 10uF, then after checking the schematic in the Boss service manual realized it should have been 47uF.
Built the second prototype with 47uF, both function and sound identical.
There is also one transistor listed as a PNP BC560? all the rest are BC550 NPN. is this correct or a misprint?
No that is correct, it's supposed to be a BC560 but any BJT PNP would also work. I used a 2n5087 in mine. (Just mind the pinout orientation)
