SOLVED Caesar Chorus no blend
Robusto
Greetings,
Just finished this pedal and I have silence on the right hand side of the blend knob which means no effect. Is there a schematic?
rmfx
Ok, so things are working through the input and out. 4558 path is fine.
Are the BBD's legit? Are they put in the correct way?
Does the rate LED pulse?
Transistors in the correct direction?
Got any pics you can post?
Gordo
Is it boxed up? Mine had the same issue but worked out of the box. Ended up being a pot shorted to the body of the one in front of it.
Robusto
I swear, sometimes all it takes is for me to post here and suddenly the problem magically becomes apparent. Just pulled the BBD chips to make sure they didn’t have any bent pins...they were both the same chip. :(
Problem solved. Thanks!
