Getting some noise that matches the rate but only when the lag knob is turned up. Noise is at the speed of the rate knob and volume is proportional to the lag knob.
Also getting a little bass loss when using the pedal (maybe this is normal with chorus, I’ve never used one)
Can't tell which chip you're using for the LFO. If you're using a TL062 or 072, try a TL022. Lower current draw, less susceptible to adding noise to the rest of the circuit. Won't affect the sound in the slightest.
Weird the build doc I have says TL072. But the build doc online shows TL022. I knew C3 changed but not the IC. I don’t notice any noise should I just leave mine as the 072?
