Champagneperfume
Hey gang,
I'm troubleshooting a Calamity Fuzz build. Wasn't crazy hard to populate but I'm in need of some help.
LED turns on, Works when bypassed, but no effect. I can hear hiss and different frequency range changes when I flip the 3 toggle switches, so that must be a good sign.
I tested each component pre-populated so it can't be that. This is the first build I've needed to use a 5v1 zenner diode, and i used an NTE5010A.
I've read on a couple other posts about biasing the J201's and making sure the drain resistors are proper value. These posts specifically discuss the PedalPCB SOT23 adapter but I used thru hole j201's via Tayda.
Can anyone walk me through or send me some info on how to do this? I'm pretty frustrated. I'm def going to start using those adapters from now on.
Anyway, thanks a ton and much love.
