Looks awesome. What kind of switch did you use for diode selection (Mode)? I started this build recently and also want to mount the switches externally.Diode options on a 2X4 switch (Mode)
External Presence
Lots of wiring under that PCB (Used the long pin, right-angle pots to boost the PCB up and over the wiring)
Here it is.Looks awesome. What kind of switch did you use for diode selection (Mode)? I started this build recently and also want to mount the switches externally.
Ahhh, thanks. Nice idea. I was thinking the obvious choice of toggle switches, but this looks really clean.
^Very neat "MODE" switches- very neat, indeed.
I just noticed the fancy double-contact jacks you've used here- do you know what this type is called? I'm interested in trying some like that for the main in/outs of my pedal board, and probably a guitar & bass or two.
Wow that’s amazing!!!Buddy requested I build this for him.
Hammond textured enclosure
Reverse-etched faceplate
External Presence
