Ok, ignore the first post, except for the mod board schematic. Now, i’ve posted this question out on Madbean (I have lurked there as long as here, probably longer, but have posted very little) as well, but sometimes you guys are a little quicker answer. Question is, the Wavelord ext jack has the ability to control the LED half of a vactrol so, does the ext jack signal also transmit the wave shape in use or just the rate? End goal is that since the Mod pads on the Parasit Studio Sonic Reducer I am building are simply attached to the LDR portion of the mod daughter board, if the Wavelord does what I hope it can, I would simply solder a vactrol between the mod pads on the Sonic reducer and a 3.8mm jack so that I could use the Wavelord to control the modulation on the Sonic Reducer. What say you, too simple to be real?
