Can someone check my Tayda UV PDF file?
I'm trying to make a small run of Katana clones and want to make sure I did this right. My first attempt wasn't great - I messed up the layers/vectoring of the text. I have a PDF that I made in Affinity and an Inkscape file, not sure how to upload the svg/inkscape file.
I saw your post on Reddit, you'll print them on white enclosures, right? (just to confirm that you don't need a white underlay).
I'm on an older version of Illustrator, but I guess you have your gloss layer and your color layer separate, so it should be fine.
On a side note, you should just have the full circles for your gloss layer to simplify the file. It should print fine as is, but would be better in a design perspective.
Correct I'll be printing them on white. Thanks for the note on the gloss layer. I wasn't quite sure how it works but that makes sense to just make circles for them. Question - when I'm printing on something other than white, does the order of the layers matter? Or will they always print White>Color>Gloss?
The layer order probably doesn't matter for printing order with the white and gloss layers being spot colors. I still always set my files up in that order though.
Opening your file in the most current version of Illustrator the gloss wasn't a separate layer for me. I separated them out and also unified the gloss layer's circles as @SYLV9ST9R suggested. The artboard was also a few tenths of a mm larger on both sides, which I know is a common problem outside of Illustrator, so I fixed that too.
Thank you! Not sure why layers didn't show up on the new illustrator, I checked it with Affinity, Inkscape, and Adobe reader. Oh well, thanks for your help!
Alex is probably right, as I always have them like this and they print fine:
GLOSS
COLOR
WHITE
Not sure it matters (as Alex stated, the Roland swatch are spot colors so the White print first and the varnish last), but I was mainly asking because I was going to suggest to use a white underlay under any color for other enclosures.
