Captain Bit - sub 5.6 Ohm for 4.7 Ohm resistor?
Cucurbitam0schata
Super excited for my first build. All the parts came in, and I started soldering yesterday. I got my work cut out for me, I ordered all 1/8 watt resistors for some future builds, and those things are tiny!
Resistor #100 calls for a 4k7. It looks like I received a packet of 5k6 Ohm resistors instead of the ordered 4k7's. I'm no pro... but 0.9 Ohm differential sounds pretty small to me, plus it's for the LED. I got a bunch of different LEDs with my order (why? for funsies), so I bet I could just swap around whichever LED looks the best with the 5k6 resistor? What does the hive mind think?
The best zoom I could muster:
(green / blue / black / silver / brown = 5k6 Ohm @ 1%, right?)
(yellow / violet / black / silver / brown = 4k7 Ohm @ 1%)
Thanks for the help, pals!
If you stated soldering now would be a good time to check if you ordered more resistors in that low ohm value. 4.7 ohm (aka 4r7) is 1000 times too small. What you want is 4k7 (aka 4.7k, which is short for 4700 ohm)
Ha, well this is embarrassing! Thanks, ya'll, for helping me dot my I's and cross my T's. I totally messed myself up when ordering! Noted: I wanted to order 4k7's, and I ordered 4.7's (and looks like I received 5.6's*?).
Luckily, I got a bucket of 10k's, and sounds like that will work in a pinch for an LED resistor.
And if anyone's in need of 50x 4.7 Ohm resistors, you know who's got some extra. ;)
(*Bonus Round - just testing my color code skillz. Did I interpret the resistor color codes right? Do you see the sequence as green / blue / black / silver / brown? And, that equals 5.6 Ohm @ 1%, right?)
Glad you caught it. Since your just starting out I should mention something that I wish I would have done early on. That is, keeping a log of all the parts you order for PedalPCB builds. After building a few pedals you will find that a lot of stuff overlaps so it's not a bad idea to stock up on certain components. You may even get to the point where you can build something you want from parts you already have. That's a good feeling. It takes a while though, but no reason to not start now.
