1) C10 (100nF) is listed on the parts list and the schematic, but I'm not seeing it on the layout.
@PedalPCB - You mentioned that this is a revised layout... was C10 removed from this version of the board? Or is it still needed in parallel with C6? (Or as a jumper somewhere?)
2) I'm doing my own drill template, but it looks like the one attached to the build doc doesn't quite line up with where the pots are on the board. It looks like the layout is spaced a little wider than the pots on the actual board. Might be worth double-checking.
