How does the the new vtl5c4/2 XVive reissue work with the CDXL? The data sheet is a bit lacking (at least last I checked it was), so I’ve been a little hesitant to use it.
If the XVive reissue meets the same specs of the original vactrol, all should be good. Which datasheets were you comparing? I found them for both the original Vactrol and XVive re-issue and the min\max resistances on the light\dark values are near identical. You should be good to go.
The off resistance in the original data sheet is ... 400R .... which cannot be correct. The graph suggests that it’s (probably) 400k. The reissue has a minimum off resistance of 500k.
I’m wondering since the initial data sheets seem wonky if they are good replacements (as they are expensive). The rise/fall times look good. And here that’s rather important.
