MichaelW
- Build Rating
- 5.00 star(s)
Update: 12-16-22
@Robert has released a revised version of this board to address the "white noise" hiss reported by a number of folks.
The hiss was tolerable playing clean or with low gain but kick in a higher gain pedal and it got pretty distracting.
It was a shame because I really like the subtle coloring this pedal added as a boost. It wound up on the pedal shelf.
When revised pedal was released @Robert offered to send me a new board or try the mod to my existing build. Never one to back down from some squeamish surgery I decided to try the mod first.
I had forgotten that I had already semi-borked this board when I installed the wrong pot and pulled a pad removing it. So there was already a flying jumper to fix that. So what's a few more cowboy mods right? .
Anyway, those of you that have built this pedal and want to try the mod, it's actually pretty simple and COMPLETELY addresses the "hiss" issue.
Here's the mod:
So as I was removing the 470n cap at C3, of course I pulled another pad along with part of the trace.....ugh....so I had to run a small jumper underneath the board and run the C3 leg to R2 output.
I decided to do the mod up top where I could have a little more room.
I was surprised as all get out when I fired it up and it all worked! Hahaha....
There is a "slight" attenuation to the gain. But this pedal had TONS of gain to begin with. I could barely crack the knob at the "High Impedance" setting.
With the mod there is still a ton of gain to push an amp.
At the High toggle setting, unity is now around 3 on the knob.
At the Low toggle setting (where there is a bit more coloration) Unity is around 5.
All with no noise.
So glad to put this sweet boost back into rotation!
Thanks @Robert !!
Original post from 8-9-22 below:
Double dipping on the build reports today.
I was originally planning to post a 2fer build report with these two pedals assuming they would be very similar.
But as I mentioned in my EV Preamp build report, the forum seemed kinda quiet this morning so I went ahead posted that build report separately.
Regarding the notion that these two pedals would be very similar, I could not have been more wrong. This is a very different pedal.
First off, there is a ton of gain in my build. To the point that I'm wondering if I did something wrong. I mean unity is literally about 2 on the amp knob that I used in Low mode. In High mode I can barely crack the pot and I'll be at unity. I don't know if swapping to a linear pot would help or not but I'm thinking about it.
Secondly, I am hearing a little bit of the white noise that @coltonius mentioned in his build report. It's in the background and is there when the pedal is engaged.
I can hear it when I play with my headphones but it's not noticeable through my amp or monitors, but it's definitely there.
Not sure if it's a charge pump issue or as @coltonius surmised a circuit noise floor issue. I don't find it distracting or anything but there is some hiss.
I imagine a real Boss CE-1 would probably do the same thing.
Tonally, it's what I expected, a subtle warmth to the tone and added girth. More noticeable playing clean than with drive. Paired with an overdrive or pushing an amp it sounds like a really hard punching boost.
I really like the way this sounds but somehow I need to tame the output, it's barely usable it's got so much volume.
Tight fit in a 1590B but mainly because my drilling was a skootch off, hence the toggle washer and slightly crooked PCB in the enclosure. Oh and I put one of the 470nf caps in upside down. These little things drive me nuts.
@Bricksnbeatles did you build yours yet? I'd love to hear how yours turns out.
Here's the mod:
All with no noise.
Thanks @Robert !!
