cgmason1986
I can't figure out what's going on and not sure what to check? I'm getting a bypassed signal, footswitch is activating the LED's, both LED's are working, the rate LED reacts to the rate pot, but I'm not getting any chorus effect? The only thing that I can do to the pedal to have it make any kind of noise is adjust the internal trim pot, either full close or full open will just make a pop sound and I'll lose signal all together. I'm using a MN3101 (I've got one from the same seller in a working delay pedal, so that chip should be good, but I did try another one just in case, no difference), a MN3007, ordered off ebay from a stateside seller so I hope it's good. Using a 1N4742 12v zener. I've got it on a socket because I wasn't sure what chips I was going to use - when I remove the diode nothing happens, still have signal passing. I soldered the jumpers on the "3007" side. Any ideas?
